Opportunity to copy group curtain reinforcements to the upper floor
M.sa
Hello, group curtains such as elevators and stairwells, especially in high-rise projects, in projects with many floors similar, provide a great advantage in terms of time if the reinforcement set on any floor on the lower floors can be copied to the upper or desired floor. Good work
What would you think if there was such a feature, please, for columns and curtains, I manually equate each column and curtain reinforcement on all floors, I repeat the analysis, I correct what needs to be changed, how would it be if a feature was added for each column and curtain instead of accepting the results of the upper floor reinforcement as the minimum for the lower floor. What if there is an option to equalize the column and curtain reinforcements on all floors, whatever the maximum reinforcement situation is?
If the option to equalize the reinforcements on all floors is added in the reinforced concrete parameters of the relevant element, the reinforcements of the building elements with the same name on all floors (column, curtain, beam, slabs) are added, especially for columns and curtains.
As a matter of fact, these features have been brought to the column and curtain in the last version. in the analysis reinforced concrete parameters.
