Opening the curtains
Re: Making Spaces for Panels To create spaces in the panel, after defining the panel object, click on the architectural plan/pattern plan mode line from the Tools menu. Click the door window command. Enter the door window settings and set the dimensions of the space you want to create in the panel. Place it on the relevant panel.
Re: Opening Spaces for Panels I would appreciate it if you could help me, it's an emergency.... I'm going to open a door for a curtain in the basement, but the program is closing, I'm using ide 7.
"azadkpln":57s72e2o" said:
koloy, I would appreciate your help, it's an emergency.... I'm going to open a door for a curtain in the basement, but the program is closing, I'm using ide 7[/quote ] Hello, if you are using version 7, the problem you are encountering may be caused by the video card or video card driver. Deactivating -use open GL hardware accelerator- option in Settings / General Settings Dialog and working can solve the problem (after canceling open gl accelerator). Do not forget to close and open the program afterwards.) If the problem is not solved, install the teamviewer program and call us.
