Object warning far from original
Hello, This is usually caused by imported dwg files. To delete objects far from the origin: -Enter layer settings, click 'Open All' and 'Resolve All' buttons. Exit the dialog by saying OK. - Check the geometry. -Select any line that gives the warning by clicking with the left mouse button. -Click the button to select objects with the same results on the relevant floor. -Close the geometry control window and delete it by pressing the 'Delete' key on the keyboard. Repeat this process on all floors that have been warned. Good work.
If you did not create your project away from the origin, your project data will not be deleted. If you select all objects on the relevant floor and the objects belonging to the project are selected, it means that you have created it at a far point from the origin. You can move all your elements to the point close to the origin by selecting the move command.
