Object intersected with an object belonging to static mode
gencideci
While friends are defining the infill curtain in architectural mode, it gives this warning from time to time, but it does not interrupt my work and continues to define the infill. why is it giving this warning? Does it affect the subbasement I have defined?
The warning in this message is likely that the curtain you entered is cutting a string. Even if the jeans do not actually cut in three dimensions, the program gives this warning. This does not affect the flooding you describe. If you disable the "split intersections" icon, it will not give this warning. In this case, division does not occur and you may not be aware of intersections. You need to do a more careful data entry.
