Number of beam bottom flat reinforcement
yasardelazi
Hello, I have beams with a net span of 6.5 meters. I raise the minimum purchase price before analysis. There is an increase in the number of top mounting reinforcements, but the bottom flat reinforcements generally remain the same. It throws 2 pieces of equipment that I said the same. For example, I can calculate the min. number of lower flat reinforcements. I want it to be 4. Would you help me with this topic
Re: BEAM NUMBER OF LOWER REINFORCEMENT
"yasardelazi":tk95km80" said:
Hi I have beams with a net span of 6.5 m. Before the analysis, I increase the minimum purchase price. There is an increase in the number of top reinforcement reinforcements, but the bottom flat reinforcements It usually stays the same. It throws 2 pieces of reinforcement I said the same. For example, I want the number of bottom flat reinforcement to be min. 4. Can you help with this
- Analysis and Design - Reinforced Concrete - Beam parameters - F1 function key - In the window that opens " Max. mount + flat spacing" header.
