In addition, can you attach the project file where the situation you mentioned above occurred? Let's examine your problem too. Good work"berkehan":1vlzillp" said:The program takes 2 minutes He gave the calculation report of the analysis in exactly 15 minutes. This is amazing.
In the project you added; -P06-07-08-22 numbered basement perimeter curtains on the basement floor are included in the group curtains -Do not include basement curtains in group curtains. Also, the names of curtain groups in the basement are not given the same as the upper floors. Group the curtains in the basement as below, as in the picture. -P08 curtain seems not connected to P01. -Correct the column-beam intersection error given as a warning in the geometry check When the above-mentioned errors are corrected and the analysis is performed, the report is generated on my computer in about 1 minute.Note: -In the Analysis settings/General Settings tab, select "Eccentricity and basement calculation method" in the final analysis, "Calculation with Dynamic Eccentricity and two loading states. I suggest you choose "ntem". You can check the link below on the subject."berkehan":1m1qmetu" said:I'm uploading a sample project. By the way, I would be happy if you could mention the deficiencies you see in the design.You do not have permission to view link Log in or register now.
Yes you are using If the machine has the features we recommend, it takes approximately the same amount of time to receive reports as the analysis time. Most of the time, it takes less time to receive reports. It varies according to the project. As for the reporting period we mentioned, it seems that the change that Levent suggested to you in the project you uploaded has not been made. Levent Bey will tell you that the screens of P01-P08 have not been changed. He wrote that the report was not connected and therefore the report took a long time and suggested that you make this correction.The project where this correction was made: This corrected project With my 5 years veteran laptop, the analysis time is 33 seconds and the reports take 40 seconds. The computer I use:"berkehan":4n7clkng" said:The model containing the changes that Mr. Levent said is attached, Mr. İsmail. If there is a reanalysis in the background while taking the account report, shouldn't it take about an analysis time? Thank you for your attention.You do not have permission to view link Log in or register now.
