NOT DRAWING A DIFFERENT SCALE COLUMN APPLICATION
Bolvadinim
1:It is not possible to place [/b][/color] on the application plan together with the curtains between the columns close to each other due to space narrowing. 2: In the drawing settings, Scale parameter does not work,(1/x) part scale 1/20 parameter, it is not possible to get ablation in 1/25,1/30 scale. 3: The openings of some curtains on the same floor are not made on the application plan. However, we have to draw them together on the same floor.
yes, I have been experiencing the same problem for years. Columns that are close to each other in the column application plan always seem to be interlocked. I can recommend a way to fix it. You can reduce the scale of the column locally with the scale command.
Here's what to do: 1. Mark the cramped or insufficient scale columns before the column is applied. 2. Get the Drawing/Column application plan. 3. The columns you have marked will be drawn as 1/50 without detail. 4. Back to the plan again. 5. Uncheck the columns you marked (check the others if necessary), re-apply the column as the 2nd sheet. Those columns will be prepared in detail. 6. When you are on the 2nd sheet, copy the columns you drew 1/50 on the 1st sheet. 7. Go to the 1st sheet, paste those columns outside the sheet. Thus, while drawing the congested columns in 1/50 scale, you have detailed the details of the same columns as 1/20 on the column application edge. Your drawing will not interfere and you will have all the columns drawn at the required scale. I hope it was useful. Good luck with..
Thank you for the method you described, but there is no other solution to this problem, other static programs do not have this problem, has this issue been fixed in the latest versions? If there is a way we won't have any other problems, I would be very grateful if you could help.
Mr. The scale parameter where Bolvadinim marked is valid for beam, continuous foundation and rib expansions. (The program uses the beam expansions to place them on the given paper.). If you want to get the whole column application plan in a different scale, you can do this while printing your layout or you can use the layout design possibilities. The current solution for cramped columns is to mark these columns without drawing (then they will open without enlarging) as Mr. Hakan explained, and copy-paste the details to the sheet edge after drawing. We are working on a new column application plan that will do this automatically, it has not reached the 0050 update, it will be in the next.
When the polygon columns in the project I added are applied to the column, D122 and D 123 slide down 5-10 cm, why might it be caused? respects
Columns have to be enlarged relative to a point. Determine the origin (placement) point of the polygon column according to which point you want to remain fixed in the application of the polygon columns... The relevant columns are scaled at the point you place. For example, place the polygon columns from the bottom left corner, as opposed to what you did, and they will scale from left to right and up...
Thanks for your answer, but I couldn't do it. I moved it with the move command and placed it again from the lower left corner. You said ''Determine the origin (placement) point of the column according to it...'' do you mean the node point by the origin point? and how can we determine the origin point thanks.
Hakan, can you send me the corrected version of the attached project in the column application? so I just don't know if it's wrong that I made the layout of the column application of the basement floor, because respect
"musamusa":1csga0ja" said:
can you send me the corrected version of the attached project in the column application, so I just don't know if I made the layout of the basement floor as the layout of the column application myself, because respect
I can't give technical support to our demo users at this level However, other participants who follow the forum will help you if they want... Note : When placing polygon columns, place them according to the point you want to be fixed...
Hakan, I tried it and it didn't work, so we can't change the location of the polygon column according to the point we want it to be fixed, there will be a connection problem. I do not want technical support, thank you, you have helped enough, I just wanted to show the correction of these polygon columns in the column application. Thank you for helping or not.
"musamusa":4hgtjvif" said:
thanks for your answer, but I couldn't do it. I moved it with the move command and placed it from the lower left corner again. You said ''determine the origin(placement) point of the column according to it...'' do you mean the node point by the origin point? and how can we determine the origin point, thanks.
I'm copying from idecad help; The offset of an existing polygon column can be changed from the Polygon Column Settings. To do this: Select the polygon column to be changed offset by left clicking the mouse. Click the Polygon Column button from the Column Settings dialog that opens. The Polygon Column Settings dialog will appear. The selected polygon column will be displayed in the Design Window here. Click the Origin button with the left mouse button. Click with the left mouse button on the point where you want to move the node point of the polygon column on the design window. (To catch the dots For convenience, you can adjust the grid spacing here as you wish and benefit from the grid locking feature) The offset of the polygon column will change. Click the OK button to close the Polygon Column Settings dialog and then the Column Settings dialog. The misalignment of the polygon column will change in plan. In some polygon columns, you need to set the origin from the coordinate box. Also, after determining the origin, check your column in the pattern plan.
Greetings, the ability to draw columns and curtains in different scales in the column application still does not work. angled curtains overlap.
Hello Mr. İbrahim, "Always detail outside" option was made in column settings for nested columns. With this option, you can have the columns you choose drawn in 1/50 scale, and have their details automatically opened to the sheet edge. Column and plan plan scales can also be adjusted in the column application plan settings. For the status of angled curtains, if you can send the project, we can make a detailed examination. Good work...
Hi Hakan, we are doing as you said, but when the details are inside, I want it for both visual and control mechanism. I shrunk the project a little and sent it to your e-mail. good work.
