Not constantly laying foundation reinforcement
hydrkrmn
THE PROJECT IS ATTACHED, WHILE THERE IS CONTINUOUSLY NO REINFORCEMENT IN THE FOUNDATION, WHILE THERE ARE EXCESSIVELY SUPPLEMENTS, I WOULD LOVE TO HELP IN THE DESIGN OF THE FOUNDATION WHEN THERE IS EXTREME REINFORCEMENT IN ONE JOB FOR NO REASON.http://www.ÜREDOrarlsc. .html]http://s2.dosya.tc/server7/8kpln2/METIN ... E.rar.html[/url]
Re: CONTINUOUS FUNDAMENTAL REINFORCEMENT DOESN'T WORK Hello, the balanced project is attached -- size (B) errors left, --I fixed the attic, the foundation, --5. I made a correction on the floor (no left and right consoles), get the same on other floors, Ünver ÖZCAN
"unver":l0zaupcf" said:
Hi Suggestion balanced project attached -- size (B) errors left, --I fixed the attic, foundation, -I fixed it on the 5th floor (no left and right consoles) and similar on other floors , Ünver ÖZCAN
ÜNVER BEY THANK YOU FOR YOUR HELP BUT WHAT IS THE PURPOSE OF UPGRADING THE LEVEL OF DUCTILITY TO HIGH WHEN WE SOLVED IT WITH THE MIXED SYSTEM, WE DON'T GET R ERRORS AND WE DON'T USE R ERRORS.
Hello
"hydrkrmn":2vq1eniz" said:
ÜNVER, THANK YOU FOR YOUR HELP BUT WHAT IS THE PURPOSE OF UPGRADING THE LEVEL OF DUCTILITY WHEN WE SOLVED IT WITH THE MIXED SYSTEM, WE DIDN'T GET R ERRORS WHEN WE DIDN'T GET THE R ERRORS. quote] We were not getting the (B) errors. If you increase the ductility level higher, the horizontal forces will affect the building less because the horizontal forces are divided by a larger coefficient. In this case, if the (B) errors occur, you need to correct them. (B) control is not done in hash and limited. These situations are at the initiative of the engineer within the constraints. When choosing, I choose by paying attention to the high-mixed-limited order. (The program wizard also directs from high to limited.) Above. In the high-mixed-limited situation, even if there is no problem in balancing in the structure, tipping can be It may not be enough in one of them. I think it is necessary to decide on the ductility level by controlling these situations. Read the information and discussion threads on the forum about 4/5R. Unver ÖZCAN
