Hi, the connections of TK29 and TK30 beams to shear columns are statically correct. The image on the floor plan originates from the trim algorithm. The correctness of the connection can be checked from the Continuous Basics and Static Results report. Foundation beam expansions are also taken correctly. For the solution of the trim problem in the plan, after getting the basic application plan, trim, line, etc. Editing can be done with commands. Good work
