Non-composite laying with trapezoidal hair
memorandum07
They helped with the problems in the project from Bursa ideyapi. Thank you. In practice, we weave concrete on it using trapezoidal sheet without using a wedge wedge. Also, when I try to get a design account report when we do the basic anchorage, the program closes itself.
Sent from my SM-N920C using Tapatalk
Hello there; Use a twisted type, not a straight bar, as an anchor in the column foot joint. Concrete stripping may occur on the flat bar, so it is not recommended. However, the breakage is a bug of the program and the problem has been fixed. In version 8.500, you will receive a warning that the anchor type is not suitable. The case of not using shear nails for trapezoidal composite flooring is not understood. It is the slip nails that enable the interaction and interoperability between concrete and steel. How do you produce a composite structure without a slip nail, is there a different application? Good work.
Hello, Ms. Nurgül, I do not claim that there will be composite flooring without stud nails, of course, I am saying that concrete flooring should be made using trapezoidal sheet instead of flat sheet. not available in this program. We don't have to use a slip wedge every time you use trapezoidal hair. I'll try changing the anchor type. ok. I also have the latest version. Good work. Sent from my SM-N920C using Tapatalk
