node move
NYILMAZ
With the node move command, I moved the raft tile edges and made them smaller as in the attached picture. Reinforcement placement and validity distances remain as in the figure. When I draw (as in the other picture), the reinforcements stay outside. A similar situation occurs in floor slabs when I move the beams on the floor with the nodal stone. Good luck with. Also a suggestion; Even if there is a link for the parameters and reinforcement selection of that element to the dialog windows that come in the reinforced concrete menus. For example: reinforced concrete column / column parameters reinforced concrete column / column reinforcement selection (general reinforcement selection)
Hello Nedim, The message you wrote is a known situation. When changes are made in the coordinates with the commands, it is necessary to delete the tiles and re-enter them in order to update the reinforcement placement and valid distances....
