nodal points
hekim
Good day, I need you to know about a subject. When placing the beams, do the beams connected to the same column need to be connected from the same node?
As long as the beams are attached to the column, it doesn't matter where they are connected, the program connects the beams to the center of gravity of the column from the column face with rigid fasteners. However, as a general rule it is good to check your 3D analysis system.
