No mass found in modal analysis
Re: LOAD NOT FOUND IN MODAL ANALYSIS
"MEHMET123":391lqb7q" said:
HELLO IN MY WORK IT GIVES AN ERROR NOT FOUND IN THE MODAL E1 ANALYSIS IN THE ANALYSIS. The direction of point loads is reversed. In order for the loads to be downwards, negative value must be entered when selecting direction Z. Or positive value can be entered by selecting direction G.
Hello. Is the ground bearing capacity 4.2 t/m2? 42 t/m2 received. Check the directions of the loads. Translated. It was taken semi-rigid. The suggestion is attached. Unver ÖZCAN
