Check drawing colors in drawing properties before drawing. The same color as the white background may be selected, or check if the panel layer is turned on in the layer settings.
Right-click on the drawing screen and enter the layer settings from the pop-up menu. Open the panel layer in the layer settings window and click OK to close the menu. the problem will be solved.
