no errors after analyzing the project then pr
yeni
After analyzing the project, there is no error, then after closing the project and reopening it and analyzing it, it gives a deflection error and enters such a loop.
Re: there is no error after analyzing the project, then file is attached. The problem with deflection was solved by increasing the beam dimensions. If you make corrections in the reinforced concrete tab and get a report without analyzing, you will only see the defect in the report. If you operate with the "reinforced concrete" button in the reinforced concrete menu, the problem seems to be solved, but it appears in the report. attached file is available.
