Re: Assembly and flat reinforcement are not visible on console beams in the report Since there is only support area in consoles, flat and assembly values are not written. The flat and assembly from the continuation of the console is continued. Look at the current reinforcement value written on the bearing. It is within the flat and assembly values coming from the neighbor. 5fi16 = 10.05 cm2. However, the current 16.21 cm2 appears. The difference is the flat and, if any, pleated difference coming from the neighbor. The problem here is that the report does not write flat and assembly in consoles?
