New Static Project
fathhh
Hello there. First of all, thank you for your interest. I have just started to draw a static project. If you examine my newly agreed project in the appendix, I would be very grateful if you could help me if there are any mistakes or deficiencies and where I need to correct.
Hi My suggestions --Fix bugs in geometry control, --2. floor ceiling (roof) remove wall loads, reduce live loads, --1. turn N13 and N15 on floor and ground floor, --Make N14 adjacent to outer slab edge, --Place column at intersection of G and 6 axis, --Close ribs in formwork plan drawing, --Check walls appear 1 m, --Foundation raft Make it almost the same as concrete and iron production, -- Solve the ladder together, -- Add the elevator machine floor -- Let the narrow side of the columns be at least 30 cm Take it easy Ünver ÖZCAN
--one. rotate N13 and N15 on floor and ground floor, you said, can I learn the reason? By the way, thanks a lot...
N15 rib works from K28 beam (end part) as cantilever, Unsupported, better to solve N15 and N13 continuous. There is the rib you put in the middle for the buckling, but my preference is to make the ribs continuous. Unver ÖZCAN
Hello, In addition to the information given by Ünver, it is seen that the mesh of the RD09 raft flooring is not formed. To solve the problem, you can connect the joint point of the TK25 continuous basis from the node point of P01 as in the example. Good work
