New load library for masonry wall weights
hkderinoz
Member
Load library----Beam Load Library For 50 cm stone wall, unit volume weights of Natural Stones vary between 3000-1600 kgf/m3. Stonewall Unit weight(kgf/m3) = 3000 kgf/m3 Thickness(cm) = 50 cm (0.5 m) Layer Weight(kgf/m2) = 1500 kgf/m2 - Mortar Unit weight(kgf/m3) = 2000 kgf/m3 Thickness(cm) = 2 cm (0.02 m) Layer Weight(kgf/m2) = 20 kgf/m2 when entering the relevant section of the idestatic program: I am waiting for your comments, thank you....
"hkderinoz":3kip4glx" said:
- Mortar Unit weight(kgf/m3) = 2000 kgf/m3 Thickness(cm) = 2 cm (0.02 m) Layer Weight(kgf/m2) = 20 kgf/m2[ /quote] For 2 cm thickness it will be 40 kgf/m2... Also why did you enter the height of the mortar 0.50 meters, not 2.5 meters along the wall height?
"HakanŞahin":3umtbubi" said:
"hkderinoz":3umtbubi" said:
- Mortar Unit weight(kgf/m3) = 2000 kgf/m3 Thickness(cm) = 2 cm (0.02 m) Layer Weight( kgf/m2) = 20 kgf/m2
It will be 40 kgf/m2 for 2 cm thickness... Also why did you enter the height of the mortar 0.50 meters, won't it be 2.5 meters along the wall height?
Thanks for your comments and corrections. Thank you... You are right, it will be 40 kgf/m2 for 2 cm thickness... I made a mistake. I think of the stone wall block without plaster, as a bonding material on a 50 cm stone wall section. I would appreciate it if you comment again. Good work...
