New load libraries for aerated concrete wall weights
HakanŞahin
Administrator
The weights of the aerated concrete walls are added to the load library of the program. In order for the aerated concrete wall defined load library to become active in your new projects, you must open a new project with new template projects. Download the file "sablonproje_gazbeton.rar" and copy its contents to the program folder. When you open a new project with a white template or a black template, the weights of the aerated concrete walls will appear in the load library. Defined load library for 2.5 meters wall height: Detailed load analyzes according to wall thicknesses are given in pdf. 10cm.pdf 15cm.pdf 20cm.pdf 25cm.pdf
