When I look in general, there is no problem with your data entry. The main reason for the warnings you receive in the geometry control is that your curtains do not provide the 1/7 ratio. Maybe, it will be resolved as a colon. Although there is no data entry error programmatically, we can say that there are errors that do not overlap with the general logic of the carrier system design. * Almost all of your outer beams are in the cantilever position from the non-continuous column. (K1-17-3-15-8-21) * We can partially understand the ones that are parallel to the long sides of the curtain, but there are also consoles perpendicular to the long side.( K12-12-23- 25) * It looks like you have a lot of curtains (most of them are in column size anyway) but their contribution to the system is insufficient. It did not provide continuity, the framework did not form. (P14-14-3-4) * You have made an inner console (K37, K39) * You have entered one band beam, this is not the logic of the tape beam and its usage. Good work.
