In combination with negative ground stress, if the maximum positive stress value is half or less of the ground bearing force, you do not need to deal with negative stress. Also (negative stresses area/total raft area) <0.20 you don't need to bother. The values I have given are very rough values. Negative stresses should be reviewed and evaluated by the engineer. If the ground stresses due to vertical loading are not abnormally asymmetrical, you can ignore negative stress at all. If vertical loads create abnormal asymmetric stress, it is a more important issue to first make the load-bearing system of your structure symmetrically balanced and correctly arranged in terms of vertical loads.
