Ndmin<0.1Acfck very urgent help please
I chose the ductility level mixed and analyzed after entering the analysis values. There is no problem, but in the strong column control in the column report, controls such as Ndmin<0.1Acfck came out.. the report did not give any errors. Is this a troublesome situation?
"muhammed my departure":efic3ttl" said:
I selected the ductility level hash and after I entered the analysis values, I did the analysis. There is no problem, but in the strong column control in the column report, controls such as Ndmin<0.1Acfck were found.. the report did not give an error. is this a troublesome situation? ?
It is not. Nd being less than 0.1*Ac*Fck indicates a situation, not a problem. Related TDY 2007 item 3.3.5 and item 3.3.5.4 a) You can check .
