my site cannot be resolved
hkderinoz
Member
The error in the figure may be caused by the cause. I am sending the 7.17 demo 64 bit.system file, thanks, good work...
The stairs are modeled to be solved together with the building. Its edges transfer load to the floor landing.Change the stair support settings with the option connected to the floors and activate the Semi-Rigid Diaphragm option in the Analysis settings General tab.Or you can solve the stairs independent of the structure.
Re: system cannot be resolved thank you for your attention. I just want to get some information from you. When we solve the stairs together with the building system, can you inform us about making the system semi-rigid diaphragm, if you don't have time, you can also send a source. thanks for your time, good work...
