My project throws a second order error
Re: Help
"hatice.mert":4fzaaj6r" said:
EVEN IF THE RAIL FUNDAMENT IS NOT DEFINED ON THE GROUND FLOOR IN MY PROJECT, I FIND 2 DIFFERENT FLOORINGS IN THE ANALYSIS AND GIVE A SECOND-ORGIN ERROR HOW CAN YOU DEFINITELY EFFECT? ?
Hello, The program finds 2 different rigid diaphragms without the console floor defined alone on the ground floor. The program asks you about the status of rigid diaphragms because console slab has no physical connection to other slabs on that floor.
Re: Help In your project, the wall load difference is high between the upper floor and the lower floor... Examine the values given in the B1 irregularity in the earthquake regulation general report.
