Thank you very much Mr. Hakan. It gives 'Insufficient Number of Modes in Dynamic Analysis' error.. Shall we create a new one from 'Modal Analysis->Modal Analysis Cases->New Modal Analysis Case' using the structure tree and write the 'Mode number' in this window? Are we going to increase the number of mods whose name it shows as 'Modal' during the analysis, then from where? Increase the number of mods where it shows 'modal'.
"ghost_13":ogkf5b0p" said:
Another question in this project is the thickness of the helix staircase in the middle, whether it's the thickness of the other stairs, even when I reduce the thickness by 5 cm, it doesn't give an error, or if it gives an error, I can't see it in the 'ladder reports' or 'reinforced concrete' section. ...
By using the bending moments found after the shell analysis, the program makes reinforcements according to the minimum reinforcement ratios given in the ladder parameters. You have to control the upper limits. Also, we cannot define a curvilinear axis in the program. It is useful to look at the maximum moment values in the 3D frame.
How can I understand that my stairs are faultless according to the Supporting conditions I have defined. Or are the stairs in my project faulty? How can I be absolutely sure.
In the frame view, you can see if the ladder is attached to the surrounding elements. you know.
