Hello, The problem is caused by the column header placed under the S24 column. To solve the problem, delete the column head and place it again in normal floors. Some other findings; *The column object S35 in the 1st basement, ground and mezzanine floors is defined as the panel object in the upper floors. *It would be appropriate to model the basement perimeter curtains as shells. Good work
