My Persistent and Singular Fundamental Problem
metingon
I keep making a topic like this, but you did research on the site, I couldn't find it. In the video narrations, the columns are in line, my project is not, the columns are not aligned, and there is something like this. Is there a curtain on a continuous and singular foundation and do we throw a bond beam on a single foundation 3. The question is, do I enlarge the dimensions of the foundations that do not save? must
"metingon":15a7j0d4" said:
columns are aligned my projected columns are not aligned
It is not a problem if the columns are not aligned. The foundation system is chosen accordingly. Continuous foundation angle can be entered. Raft can be made. Single foundation - A continuous basis can be mixed. It is decided according to the situation.
and there is such a thing as whether there is a curtain on a continuous and singular basis
There is a continuous basis under the curtain entered as a panel, there is no single foundation The curtain entered as a bar can be one end of the continuous foundation, while the singular foundation is alone.
and do we lay tie beams on single footing
We lay tie beams from single footing to single footing, from single footing to continuous footing, and/or from continuous footing to continuous footing.
3. The problem is, should I increase the size of the foundations that do not save, what should I do
The answer to this depends on why the foundation does not save and the foundation system. For soil tension, it is generally necessary to increase the floor area, and in cases of exceeding the cut/punch control and/or insufficient reinforcement, increase the thickness. You cannot get accurate help because you did not add the project. (where you entered your basic data and said you didn't recover it)
Sir, I have saved foundations all the time, but look, is there a place I drew wrongly? My single foundation does not save any, how can I do it, I will draw raft and raft without beams, I will draw these on a sketch from these projects.
* P01-P02-P03 curtains entered on the ground floor were not entered on the basement floor. Flooring system in the basement floor is not entered. Therefore, do not define the basement as a separate floor. Add the basement floor height to the ground floor height. *ST1-ST8 foundations are not connected to columns. *The level of the D106 slab on the ground floor of the project is incorrect. If you want to lay low, you must enter the level as -30 cm. When the floor is given a positive level, the beams limiting the floor and the columns to which the beams are connected should also be given elevation and upper level. *It is recommended to pay attention to the warnings in the geometry control. Examine the attached project and its foundation system. If there is a point that is not understood, contact by phone...
I always thought that curtains cannot be thrown on the basis, I deleted it, I will look at the other places we have mentioned, I wonder how my singular foundation will be.
"metingon":10x68aqt" said:
I thought that the curtain cannot be cast on a continuous basis, I deleted it, I will look at the other places we have mentioned, how will my singular basis be?
Single Base data entry is correct. A single base will be defined under each column. not defined)Single foundations can be connected to each other with tie beams. There is stress problem in individual foundations. The stresses are quite high. It is recommended to apply a continuous foundation or beamless raft foundation instead of a single foundation in the project.
Good day, I am writing here because it is a topic opened with Basics, I did not open a new topic. Can we calculate singular basis with idestatic? So, for example, I designed a steel building. I have the basic reactions to it. I wonder if I create the foundation system in idestatic, can I transfer the loads from the other account (automatically or manually) to here and calculate the foundations here? I tried a little, but I could not get a very successful result. Thanks in advance.
I need to draw a single foundation, sir, what should I do? In order to save it, I will also draw rafter raft and non-beam raft on this project, should I add curtains to the foundations and lay a floor...
"yagmurcankocak":1md0prn2" said:
Good afternoon, I am writing here because it is a topic opened with Foundations, I did not open a new topic. Can we calculate a single foundation with idestatic? So for example, I designed a steel building. I have the basic reactions of this. If I create the system, can I transfer the loads from the other calculation (automatically or manually) here and do the calculation of the foundations here? I tried a little, but I couldn't get a very successful result. Thanks in advance.
Normal force and moment can be entered into the column. A solution can be made by entering the system and defining the effects close to the lower ends of the column.
How do I save a single foundation, should I add flooring, should I add curtains to the basement, should I draw it...
"metingon":1mdiqf7l" said:
on this project I will draw rafters and rafters on this project, should I add curtains to the foundations and lay slabs ... I connected them with a tie beam, but the studs stopped on the tie beam
The raft foundation system was a raft without beams. Design it as a slab Create a closed area with the slab edge and place a raft slab in this enclosed space
"metingon":45ocwaki" said:
how can I save a single foundation, should I add flooring, should I add curtains to the basement, should I draw ...
The project cannot be solved by correspondence in the forum. I recommend you to get training on the use of the program. Let us know which city you are in Let's try to direct you to a place where you can get training Tel: 0-224-220 67 17
"metingon":1rjcu7kf" said:
I'm in Tokat, sir. Didn't I draw the foundation on the basement floor
Since you are using the demo, I guess you are a student and you are doing your graduation homework. Is it true? If you send it to [email protected], when your information reaches us, we will get back to you for the training date (if you are a student). , training is given in our Istanbul office every month. Even if you are not a student, you can attend one of these trainings if you wish.
I didn't have to say it, there's just such a thing, now we're going to draw them on the sketch, so I'm pretty nervous, I can't draw the foundations, how many days have I been struggling?
