my own settings
matrax
friends, what should I do to get the same settings in the project I made before. For example, the 19-gauge brick I used on the beam, the scanning style on the beams, the materials I used, etc. (I change them in my first project, should I change the settings again when I draw a project again?). It says set, it doesn't see any of my files. I'm waiting for your help
"matrax":1bqnmc6e" said:
guys, what should I do to get the same settings as in the project I made before. For example, 19 bricks I used on the beam, the scanning style on the beams, the materials I used etc. I do not change it.. it says load the settings from the settings section, it says set, it does not see any of my files. I am waiting for your help
What I want to say is not only on the beams, but when starting the project, for example, I want to start with d=15, etc. While using the material, values such as let my project use c20 and get the basic ground stress 10 from the analysis brackets.
"matrax":1uk6woz1" said:
I mean not only on the beams, but when I start the project, for example, I want to start with d=15, etc. While using the material, my project should use c20 and the base soil tension should be 10 from the analysis braces
I think we are talking about the same issue.. . An empty project that has been set in the program can be saved as a template. Templates are typical projects. When opening a new project, any previously registered template can be selected. The settings of the template selected when opening the project are also activated in the new project. The templates are stored under the template folder in the program folder. Under the Template folder, there are the default project file and the folders created by the program during the installation of the program. One of these folders is the User folder. A new template can be saved in the User folder. However, you can also open other folders to classify the templates in the Template folder using your Windows Explorer. A template project to create : Become a template Open a project with the settings you want to save. (Delete the data if you don't want to use the data in the project here) Click on the Project/Save As line. The Save Project dialog will open. In this dialog go under the template folder under the program folder. Double-click the User folder. Give the file name a name and click the OK button. The template project will be created. If there is anything unclear, you can contact us by phone. Tel:0-224-220 67 17
