If you are making ribbed floors, why don't you connect the columns S2 and S3 with a beam at tooth height? Likewise, why don't you make the S10-K5 and S10-K18 connections. When you do these, I think that there will be no deflection problem, regardless of the rib directions. In addition, your system will be a more accurate system.
