My first project can you give me suggestions
ahmet5410
hello, my first project that I'm working on now has been completed at a large stage (as a model) I think I made a lot of mistakes, especially when I was doing the analysis, earthquake load, reinforcement etc., can you give me suggestions by examining my project, and my reinforcement amount is 85 tons, my experienced friends say that it does not exceed 65-70 (they use sta4cad I couldn't get help from them for this.) The equipment calculation per m2 is a subject that I do not like and a comparison that does not suit an engineer, but it should not be skipped without thinking. What are the main options or reasons that reduce or increase the amount of reinforcement, your suggestions, the ways you will show, will be a start on my way, I am waiting for your help, thank you very much in advance. my project is in the Link
Re: first project help Hello --If you enter the wall loads with the wall icon in the program, you can give the wall gaps, and you can see the walls on the perspective screen and minimize your chances of error. My suggestions: --Since the building does not have a basement. You have removed the basement tick from the general settings, --As the floor is group C, it can be increased by 50%, --Lower the double beams (on the other sides of the building) seen on the attached floors to one. It may have come because the basement floor has been copied, --Slide/enlarge the columns in the places I have given in blue, put beams in the places I have given in red, --Moving load on the attic floor, --You need a floor to support the elevator floor and the elevator machine, --1. Remove the flooded curtain tick on the curtains connected to the floor slab in the basement, --The narrow side of the column should not be less than 30 cm, -- Brace the ladder and dissolve it together with the building. After these corrections, you can share again if needed. Unver ÖZCAN
Re: first project help thank you for your suggestions, that double beam was copied at the last moment, I didn't realize I sent something like this, sorry for sending something like this, I'm going to model from the beginning considering what you said, I will consult again if I have any questions :) and I have no idea about the stairs No, it will be difficult for me to solve it
