Mushroom Flooring
Murat K.
Hello, In the single-storey model that I sent in the attachment, cork flooring with denim was made at the request of the architect. Since I have never done a design like this before, I have my trepidations. When I analyze the model, there is no problem. Do you think it was a correct modeling? Best regards.
"Murat K.":n36ommgc" said:
Hi, In the single-storey model I sent in the attachment, cork flooring with denim was made at the request of the architect. Since I have not done a design like this before, I have my mistakes. When I analyze the model, there is no problem. Do you think a correct modeling Regards.
Hello, In the model you created, D1 and D3 slabs are not connected to the beams. In order to connect, two different slabs can be defined by drawing the slab edge between the columns on the 5 and 6 axis. The example is attached. Good work
