Moving Load reduction
civil1979
Hello; I am asking for help from those who have previous experience on how to apply live load reduction specified in TS 493 Chapter 13. The point I'm stuck on is: Should I multiply the live loads of the floors on the relevant floor with the coefficients and assign them to the floors, or should I multiply the HYK coefficient, one of the floor parameters, with the coefficient of the relevant floor. Take it easy everyone
It is correct to give the live load participation coefficient from the floor parameters dialog... because if you calculate it yourself (by multiplying the coefficient with the live load) and assign it to the floors, the loads you assigned in the floor parameters dialog will be multiplied again at the coefficient ratio... Ex: Q=200 kg/m2 ; If n=0.3, nQ=60 kg/m2.... if you throw this load on the floor, the coefficient of participation in the floor parameters will participate in the analysis and calculate this load value as 0.3*60=18 kg/m2. You can consider entering the participation coefficient as 'n=1' among the floor parameters and calculating and assigning the Q values on the floors yourself, but I don't think it is a very consistent approach... My suggestion is to define the floor parameters and assign your live loads as they are... good work, respect...
Hello, I think my question was misunderstood. What I am talking about is Ts 498 item 13. In other words, live load reduction in multi-storey buildings. I'm waiting for your help...
