Mosque Static Calculation
starvars
Hello. I'm working on a mosque, how can I fill the vertical space between 2 domes with concrete? Can anyone help?
Hello there; If you add your project, we can give a more accurate answer. As I understand from your question, as you can see in the attached images, in mosque projects, you can close the vertical gaps between the domes as reinforced concrete with a supportless curtain element. You have the chance to make realistic modeling by opening spaces inside the curtain at the necessary points. Best regards.
I can't get the drawing for the big dome and the circular beam underneath, the program hangs I can also take your advice to make the minaret round.
"el hendese":1ysgug5c" said:
I can't get a drawing for the large dome and the circular beam underneath, the program shuts down.
From the properties of one of the circular beams, uncheck the line "Continue to accept beam at right end" and analyze.
You can create the round minaret with curtain pieces by converting the circle into a curtain. - Draw a circle with the circle command. -Select the circle and press the right button on it. -Click on the "Transform/To Screen" line from the menu that opens. In the dialog that opens, enter the number of pitches. Click the OK button. Good work
Hello, I am currently working on a mosque project. When I model minarets, I get a 1/6 pitch width/length error. I couldn't find a way to do it without turning it into a curtain. Thanks in advance.
"dago46":3b325vz9" said:
hi, I'm working on a mosque project right now. when I model minarets, I get 1/6 screen aspect/length error. I couldn't find a way to do it without converting it to a curtain. I would appreciate it if you could help me with this. Thanks in advance.
Hello, In order to prevent the curtains from giving a size warning in the minaret, after completing the design, I can recommend that you fix the reinforcements and select the "curtain that does not continue in the basement / upper floors" option from the Curtain Properties. Good work.
Thank you. Well, I want to ask one more question; When defining the support of the domes, should I choose only beams in the solve options with the structure? I placed the domes on the floor, wouldn't it be right for me to tick the other options and work with the appropriate one instead of working with the beam here?
"dago46":27g8lbje" said:
Thank you. Well, I would like to ask one more question, should I choose only beams in the solve options with the structure when defining the support of the domes? I placed the domes on the floor, instead of working with beams, I do not select other options and operate with the appropriate one. Wouldn't it be correct?
The anchoring conditions of the dome sides should be arranged according to the element to which they are connected (If the floor is connected to the floor, the curtain if it is connected to the curtain, if the beam is connected to the beam, the lines connected to the beam should be marked.)
"Levent Özpak":3bj2mabr" said:
"dago46":3bj2mabr" said:
Thank you. Well, I want to ask one more question; When defining the support of the domes, should I choose only beams in the solve options with the structure? I placed the domes on the slab, wouldn't it be right for me to select other options and work with the appropriate one instead of working with the beam?
The bracing conditions of the dome edges should be arranged according to the element to which they are attached. (If the floor is connected to the floor, the curtain if it is connected to the curtain, the lines connected to the beam if the beam is connected should be marked.)
Thank you.
