Mosque Project - How to Make a Dome Drawing?
velitekeli
Hello, there is a mosque project that I have drawn in the appendix, I have drawn such a structure for the first time, there is no problem in the analysis, but I would appreciate it if you could examine it and give your opinion. I also modeled the dome of the mosque, but as far as I know in ide7, no drawing and reinforcement calculations are given for the dome, how should I do it? Good work.
It does not feel right to carry this dome with this column system. Maybe you can enlarge the diameter of the dome a little (5m) and at least bring it closer to the axles 5 and 8 and press the beams and columns.
Hello, In addition to your project; -The supporting conditions of the dome are not regulated. If you are going to solve it together with the structure, you should select the option "Supporting conditions for solution with the structure" in the dialog and mark the elements it is connected to. -It would be appropriate to enter the U-shaped polygon column S12 as a panel object and model it as an acceptance. =373[/url] Good work
