mosque dome seating
ebasakin
have a nice day. I am doing a mosque project for the first time. While solving the system, I supported the dome on the structure and I want to place the dome on the circular beam and the circular person on the floor beams and curtains. but the program gave an error during the analysis, perform geometry analysis. I am uploading the project file. Thank you for helping me solve this problem. I need to submit the project urgently. I would be happy if you check if I have any other deficiencies. Regards
Hello, In the project, small domes are sitting on the floor. However, the support conditions are arranged depending on the beam. It must be attached to the beam. In this case, analysis can be made. Except this; The round space under the D06 slab was tried to be created with the slab edge. The floor space command should be used here. The elevation of the K1, K2 beams drawn under the big dome is not compatible with the slab and the support connections are faulty. Good work
How do I need to get the beam under the big dome into the curtain there? In small domes, I couldn't make the space under it with the floor space command, but it doesn't work in a circular way.
"ebasakin":3awbf49w" said:
How do I need to fit the beam under the big dome to the curtain there. In small domes, I couldn't make the space under it with the floor space command, it is not circular.
The floor space and beam can be defined as in the example. layer is turned off.) Note: The continuous foundations entered under the panel object should be connected from the nodes of the panels as in the example project.
How can I open the dome layer from the layer settings, Mr. Levent? 2) Can I see the support conditions after I open them? 3) Do we have an option to create drum beams in İdecad? good work
