Friends, I want to return beams under the dome for the mosque project I have attached, but when I make a circular beam, it gives a geometry error. Could you please see how I can overcome this problem? I want to turn the beam and put a dome under it.
I did it using spring beam command. I replaced the dome. I used the center of the dome as the center. I added a spring beam piece by piece from the top of the column to the top of the column. I adjusted the support patterns of the dome. I placed tiles in triangular areas. I analyzed it as a semi-rigid diaphragm. So much. What else do you want to learn?
