More than 1 column in the width direction of the continuous foundation
engineer_yildiz
Dear form users and idecad officials who always try to help us, Can more than 1 vertical carrier (column/wall) element be attached to the continuous foundation in the direction of its width (not its length)? Is there a limit to the correct calculation of the program regarding the width of the continuous foundation? Thank you and have nice work.
Re: Having more than 1 column in the direction of the width of the continuous foundation Hello, It is not possible to model the curtain and column group with a single continuous foundation as shown in the picture. Your model is incorrect. In Version 7, you can model continuous foundations as a grid using column and wall nodes. In Version 8.62, a fundamental analysis model has been developed to use mixed foundation systems. If you have a chance to continue your project in 8 versions. If you delete the continuous foundation that you have enclosed in the frame and define a raft foundation with the same dimensions, you can solve the superstructure interactively, and the raft and continuous foundations together.
