missing drawings
saridurmus
Greetings, While taking the drawing of 1 floor beams in the attached project, can we see the details of the K6-K7-K8 beams?
Hello, In the Project Reinforced Concrete / General Reinforced Concrete Parameters dialog, the angle value is entered 29 degrees in the line "Continuously accept beams with a small angle difference". Since the K05 beam makes an opening less than 29 degrees with both K06 and K09 beams, it is tried to be drawn continuously with both beams. I can suggest two ways for you to get the drawing of beams K6-K7-K8. 1- In the Reinforced Concrete/General Reinforced Concrete Parameters dialog, enter a value smaller than the angle between K05 and K06 in the "Continuously accept beams with small angle difference" line. For example, 10 degrees. In this case, the K06-K07-K08 beams will also lose their continuity and will be drawn separately. 2-Insert the beam K05 at the same angle as the beam K09 as in suggestion.c. Good work
