mirror
gürkan
sa hello I had to mirror the structure I drew in İdecad and I mirrored all floors, The R coefficient got very small and it gave the 2nd and 3rd errors (related to nd) from the bottom in the error report. Can we accept the line I drew on the ground floor as a reference and mirror the whole structure to the upper side of the project you sent?
Hello, When you get the symmetry of the structure by referring to the line you specified, you model a structure with different rigid diaphragms in the same project. In version 5 such structures must be entered and resolved as separate projects. If the drawings of two structures are to be edited on the same sheet, you can combine them as a final drawing in a 2D environment. Good work.
I did as you said and mirrored all floors and the foundation one by one, but the names of the floors on the foundation and on the normal floor were recorded and the r coefficient also differed
