Hello, -I am trying to learn the program via demo. Tensile reinforcement control is carried out only in the support areas under vertical load and at the lower edge of the opening. However, under earthquake loads, tension may occur at the top and bottom of all support areas. In addition, I think that moment scanning should be done on the upper edge of the opening, which creates tension, in the middle region and up to the point where the upper support reinforcement does not work, otherwise, even a short section, the moment part that the mounting reinforcement does not meet may remain on the upper edge. Good work!
