This section is a bit special. 10fi16 or 12fi14 is too much for 1% pursantaj on the side. Since the program first looks at the minimum pursantage, it puts 8fi16 on the side and leaves it as it is (4 in the corner, total 12fi16, total 24.127 cm2 ). make 4fi16 vertices 10fi16 sides (total 14fi16 28.149 cm2) or 4fi16 vertices 12fi14 sides (total 26.515 cm2) Good work..."serhatmuh":12957ytk" said:I have a 12-storey system, why does the horizontal distance between stirrups and crossties not comply with the condition of a 25 stirrup on columns? (especially in .30/80 section columns) reinforcement 12 f16
you're welcome"saridurmus":33626re8" said:thanks. you touched on a good topic. we were fixing it manually.
