I tried to design a minaret according to the new regulation. Considering the dimensions of the minaret, errors appear in the calculation report because the wall section thickness does not provide the ratio of 1/6. Other than that, there are no problems with other controls. I designed the minaret in an octagonal shape. I lowered the curtains of the octagonal section to the foundation so that there would be no vertical continuity problem in the mid-node. I did not add stairs inside the minaret. In total, I defined 11 floors and entered tiles for each floor. I created a doorway in the basement and floor, both inside and outside curtains. I defined the 6-meter section as rigid, which will be buried as 4.5 m floor + 1.5 m foundation. In the project, I will show this part as a fill. Could you also examine and interpret the data I sent in the attachment?
Log in or register now.
