"volkan-1980":3hgp6t4x" said:
Mezzanine floor S13-S14-S24 K ( interrupt) error. No matter what I did I couldn't fix it. I would be glad if experienced friends can suggest a solution. I am also open to your ideas on general design. Thank you.
Hello. The shear safety problem in the columns was caused by connecting beams from different levels connected to the columns. (The column free length is detected as -0.1 and -0.30m.) You can change the column free height by selecting the Defined option in the Column Free Height (Ln) section of the Column Properties/Static Reinforced Concrete tab. Good work
