MENU BAR BROKEN
guvenbahadir
friends, the menu bar disappeared in the program, I don't remember what happened, I suddenly pressed them, I think it went away, how can I get it back....
Click the right mouse button where the menu bars are and mark the items (such as General, Analysis) that you want to display in the window that opens. Good luck with
The link of the menu bar is not there, there are the following (general, change, capture, drawing, analysis, change) when you right click, there is customize at the bottom, press it, select the toolbars, the menu bars are clicked, but there is still no menu bar. I deleted the program, I downloaded it again, but there is still no menu bar, last care format atcam, if I can't find a way to pc, I'm waiting maybe there is an easy way :S
While running the program, hold down the left ctrl and shift keys of the keyboard. The program will revert to its initial installation state, without a warning saying "Registry settings cleared". This should solve your problem. No need to format...
Is there a message? If the message does not appear, you are not pressing it. Keep both keys pressed until the message appears or the program opens.
