Mdev>Mo/6 is not provided, I used 4/5R in the y direction
SonDurak
HELLO THERE ; Since the condition Mdev>Mo/6 could not be met in the PROJECT, I used R and 4/5R in the y direction, but it shows this as an error in the report. I couldn't understand why. I would be glad if you help. THANKS...
Re: Since Mdev>Mo/6 could not be provided, I used 4/5R in the y direction I WANT TO ASK SOMETHING INCREDIBLE OF THE SUBJECT, THE TOPIC I ADDED WHEN I SEND A MESSAGE, THE TITLE I ADDED CHANGES ITSELF, THE PRIMARY OF MY MESSAGE IS INSTEAD OF THE TITLE.
Re: I used 4/5R in the y direction because Mdev>Mo/6 could not be met , but it shows this as an error in the report. I couldn't understand the reason. I would appreciate your help.[/quote] You may not have met the tipping condition yet. Please add your project.
Re: Since Mdev>Mo/6 could not be provided, I used 4/5R in the y direction IF SO, HOW DO YOU PROPOSE? AND IF THERE IS A GENERAL ERRORS IN THE PROJECT, I WOULD LOVE TO WRITE IT. THANKS..
Re: Since Mdev>Mo/6 could not be provided, I used 4/5R in the y direction Hello, the proposal project is attached. Fix bugs in geometry check. Solved with V10.16, if you haven't installed it, ask from Bursa office. Ünver ÖZCAN
