Hello, the slab on wall command is used to define slabs without beams and an architectural program is required for the wall. Over-the-wall slab command is not a command related to masonry building calculation."sC.oUT":2dpy9osn" said:I wonder what this icon does if we can't draw a wall??
Thank you Mr. Hakan. Good work"HakanŞahin":3qtw7x5m" said:Hello, Flooring on wall command is tiling without beams. It is used to define and architectural program is required for the wall. Wall tiling command is not a command related to masonry building calculation."sC.oUT":3qtw7x5m" said:If we can't even draw a wall, what does this icon do???
