eissenhover
Hello everyone, dear forum users, I want to know your opinion on something. We have a steel frame scaffolding project, 4.8 meters wide and 20 meters long. The pier will extend 20 meters into the sea perpendicular to the shoreline. along the pier, that is, 20 meters, the deepest part of the water is 1.5 meters. There will be 5 piles at a width of 1.2 meters (in the short direction of 4.8 meters) and in the long direction (20 meters) there will be piles with an interval of 4 meters. The piles will be Q219.1*8 pipe profile and will be filled with C16 concrete after driving. Crosses between the piles will be thrown at certain points. The walkable part of the scaffolding will be formed with IPE 200 steels to be placed on the piles and wood will be mounted on it. This is the design in my head, but there are things I don't know; 1) How should I affect the pressure of the water on the 10-meter piles (8 meters in the soil, 1 meter in the water, 1 meter above the water surface) that will be buried in the sea floor, that is, how should I enter my 1 ton/m linear load to the one meter part that is in the water, or how else should I affect it? ? 2) Is there a load other than the water pressure that I should consider? I'm thinking of adding a fixed load to the walkable part of the pier, a 500kg/m2 load as a live load, and a snow load. Apart from these, what can be the additional load, Wind ? Or another load? If there is another load that I need to affect, what method should I use? 3) Would it be right to solve such a system with idecad? If I solve it in İdecad, I will have to define the pipe profile piles I mentioned as a pipe profile column in the program, and of course, I will not be able to transfer the idea of filling the inside of the profile I thought in practice to the program, in this context, is it appropriate to solve such a structure with idecad?
