Emre.Ozcan
It's probably a topic that has been brought up before in the forum, but I still want to ask for clear information. In my project, I get the error of insufficient reinforcement on the raft basis. As a solution, I manually intervene to reduce the additional reinforcement spacing, and when I reduce it to the required interval, the error is corrected, but when I do the analysis again, the reinforcement spacing is lower than the 10 cm I entered in the raft basic parameters, so it reduces the reinforcement interval to the lowest value, 10 cm capi does not save. It is said in the earthquake regulations that it should not be lower than 25 mm, but this figure does not seem like a low enough value to me for healthy manufacturing. I would like to get the opinion of you, my dear engineer friends. Do you think it would be more logical to lower the minimum reinforcement spacing to which value for a production that will not cause difficulties in a comfortable construction site. :?: :?:
