Making revisions in the designed combinations...
smsenturk
Hello, take it easy, For example, we designed a column-beam junction, copied it to other axles. What can I do so that the change I made later in the join is also edited in all joins.
Hello there; After editing, add a name from the add to favorites tab in the lower left corner of the combination menu. Then select all other combinations of the same type and recall them from your favorites. Good work.
