Hi Ismail Sir, as you suggested, I increased my finite element widths from 25 cm to 1 meter, I was doing the modal parameters as you said, I didn't do anything there anyway. Although I made a semi-rigid solution, the analysis done in 23 minutes decreased to 4 minutes. Thank you for your help. I wish my finite element widths remained 1 meter Would I have done something wrong? What disadvantages might it have. Best regards.
"Ismail Hakki Besler":2dhwge6k" said:
"yusuf15hira17":2dhwge6k" said:
Hi; With the new program, my analyzes are completed in a period of 10 to 40 minutes. I had ram upgrades, ssd upgrades, etc., because I thought it was because of the problem. Although I increased the speed of my computer a lot, there was no change in the analysis time. Is there a way to shorten this analysis time?
while singing; Uncheck the semi-rigid option in the upper left corner of the screen. Uncheck the Uz Rx Ry Rz freedoms in the modal parameters. Make the floor and curtain finite element spacing 1m. After deciding on the design and handling the deficiencies, when performing the final analysis, if the structure does not require semi-rigid, do not solve semi-rigid. If there is no need, remove Uz from modal parameters Do not mark Rx and Ry in modal parameters
